Hello everyone ![]()
I am currently working on Reachy with the ROS2 driver. Here is what i get when running the ros2 service list command:
/camera_focus/describe_parameters
/camera_focus/get_parameter_types
/camera_focus/get_parameters
/camera_focus/list_parameters
/camera_focus/set_parameters
/camera_focus/set_parameters_atomically
/camera_publisher/describe_parameters
/camera_publisher/get_parameter_types
/camera_publisher/get_parameters
/camera_publisher/list_parameters
/camera_publisher/set_parameters
/camera_publisher/set_parameters_atomically
/camera_server/describe_parameters
/camera_server/get_parameter_types
/camera_server/get_parameters
/camera_server/list_parameters
/camera_server/set_parameters
/camera_server/set_parameters_atomically
/camera_zoom_controller_service/describe_parameters
/camera_zoom_controller_service/get_parameter_types
/camera_zoom_controller_service/get_parameters
/camera_zoom_controller_service/list_parameters
/camera_zoom_controller_service/set_parameters
/camera_zoom_controller_service/set_parameters_atomically
/get_camera_zoom_focus
/get_camera_zoom_level
/get_camera_zoom_speed
/get_joint_full_state
/joint_state_controller/describe_parameters
/joint_state_controller/get_parameter_types
/joint_state_controller/get_parameters
/joint_state_controller/list_parameters
/joint_state_controller/set_parameters
/joint_state_controller/set_parameters_atomically
/orbita/kinematics/inverse
/orbita/kinematics/look_vector_to_quaternion
/orbita_kinematics_service/describe_parameters
/orbita_kinematics_service/get_parameter_types
/orbita_kinematics_service/get_parameters
/orbita_kinematics_service/list_parameters
/orbita_kinematics_service/set_parameters
/orbita_kinematics_service/set_parameters_atomically
/robot_state_publisher/describe_parameters
/robot_state_publisher/get_parameter_types
/robot_state_publisher/get_parameters
/robot_state_publisher/list_parameters
/robot_state_publisher/set_parameters
/robot_state_publisher/set_parameters_atomically
/set_camera_zoom_focus
/set_camera_zoom_level
/set_camera_zoom_speed
/set_fan_state
/set_focus_state
/set_joint_compliancy
/set_joint_pid
Some services mentioned in https://github.com/pollen-robotics/reachy_sdk_server are not present in the above list. For example, I don’t see the service called StreamFullBodyCartesianCommands (which could be really useful for my application).
I am thus wondering if it is normal or not ? The reachy_sdk_server folder is located in my reachy_ws/src folder and I pulled recently the github repo to be sure to be up to date.
If I am not mistaken, all the services, nodes and topics are initialized when turning on the computer. Or should we call a specific command to make available the so called GRPC services handled ?
The Reachy I am working with is originally a 2019 version, but the software was updated by pollen robotics recently while the hardware still mainly corresponds to a 2019 version. Could this be the reason explaining why some of these services are not available ?
Thank you in advance,
Romain.
