Hi @raugom,
Thanks for all the details you provided.
Could you please give us some additional informations :
a screenshot of where you are blocked in the app
Are you using the executable app or are you launching it from Unity ? If you are using the app, which version are you using (written below the “Connect” button in the first screen when you launch the app) ?
Could you verify the robot and the computer with the teleoperation app on the same network ? (If you can ping it, then yes, but I don’t know if you’re using the same computer for the remote operation application and the ping)
Did you do any updates of the app, on your computer or on the Meta app between when the teleoperation was working and now?
Are you using the alias reachy2-pvt03.local in the app ? If so, could you try to put the actual IP address (you can find it in the dashboard, section Network) ?
Our culprit was the GStreamer installation. The Reachy2Teleoperation repo has links to GStreamer Windows Runtime and Development Files installers, but the latter link is broken. The Reachy2Teleoperation is supposed to use both GStreamer installers. If the link to one is broken in the repo, then it is possible the link is broken in the installer as well.
